ATC SCM 40 V2
0 Members and 1 Guest are viewing this topic. Read 5086 times.
Freo-1
ATC SCM 40 V2
« on: 8 Aug 2023, 01:05 am »
Just obtained a pair of ATC SCM 40 V2 speakers.  Should be delivered in a few days.  They will be driven by a Devialet Expert Pro 1000 with Speaker Active Matching (SAM) enabled.  A SVS PC 4000 will round out the sub bass.
Looking forward to listening to these.  I had ATC SCM 19's years ago, and was very impressed with them.  This will be a step up in playback quality, especially with the Devialet as the DAC/AMP source.
mresseguie
Re: ATC SCM 40 V2
« Reply #1 on: 8 Aug 2023, 03:50 am »
Great find!
I’ll look for your posted impressions.
Michael
Freo-1
Re: ATC SCM 40 V2
« Reply #2 on: 11 Aug 2023, 01:25 am »
Speakers arrived to day.  Will need to spend time getting to know their sonic character, but first impressions are amazing.  They definitely are able to go louder than my Dynaudio Focus 360's (not that I would ever listen too loud).
The Speaker Active Matching (SAM) does an outstanding job of extending the bass register of the SCM 40 V2.  They will be fairly easy to integrate with the subwoofer (SVS PC 4000).   Will use REW with the calibrated mic. So far, got pretty close by ear. The fact that they are infinite baffle helps with bass integration.
They do seem to have a different sonic character from most speakers.  Will need to listen to a variety of music to get a better handle, but one thing I picked up right away: They are great rock speakers.
They need a LOT of power.  The Devialet Expert Pro 1000 has plenty of power for them,  but the speakers can absorb most of it quite easily.  It needs a good 300 watts plus to really sing.
Will check back in a few days.
Freo-1
Re: ATC SCM 40 V2
« Reply #3 on: 14 Aug 2023, 03:15 pm »
Now that I've a few days to listen to the ATC's, I can report they are a remarkable set of speakers.  They are quite different in character from my Dynaudio Focus 360's, or the Tyler Linbrook Signatures I recently sold.
The various reviews I've read were all very glowing.  Many of the reviewers mentioned that they have more of a "pro audio" sound, as opposed to a audiophile sound (whatever that means?).
They have a lot of strengths.
  • The dispersion is very wide, not real need to worry about having to sit in a sweet spot to get the most from therm.
  • They were easier to integrate with the subwoofer than the ported speakers, due to the infinite baffle design.
  • They definitely can play louder than most other speakers on hand without sounding congested.
  • They sound very neutral throughout the frequency band.  No real emphasis on any one frequency band is noticeable.
  • The distortion characteristics from the ATC's are amazingly low.  It's something that really jumps out at listener when playing back music.  I wound up extending listening sessions due to the performance from the speakers.
  • Dynamics are outstanding.  The macro and mico detail presentations are very balanced.  The presentation is like sitting in the center of of a symphony hall.
Rather than post audiophile jargon, just wanted to cut to the chase on how they sound.  To me, they are at or near the top at their price point, and would easily put them up against speakers a several times there price point.  The drivers are vey good, especially the midrange driver.  The cabinet work is excellent, quite solid.
They do require a fair amount of power to get them to sound their best.  They need at least 75 to 80 watts in Class A AB.
There was a review on the ATC's where the reviewer stated the Purifi module did a poor job driving the bass.  They recommended to not use a Class D amp with them.  I'm using a Devialet Expert Pro 1000, which has a Class D current output, and Class A voltage drive.  The Expert Pro 1000 has no problem driving the ATC's, because of the fact it's 1000 watts @ 6 ohms.  The Speaker Active Matching (SAM) with Devialet supports the ATC, which safely extends the bass of the speakers.  The Expert Pro/ATC combination sounds extremely good, could not be happier with the sound from this setup.
Also tried the ATC's with a tube amp setup, which has 90 watt mono tube amps.  That also sounds very good, with dynamics not as robust, but a more lush midrange.
In conclusion, the ATC SCM 40 V2 speakers are most highly recommended.  The active version is also well worth looking at as well.  If I didn't already have the Devialet, would have given the active version serious consideration.
« Last Edit: 14 Aug 2023, 05:00 pm by Freo-1 »
dflee
Re: ATC SCM 40 V2
« Reply #4 on: 14 Aug 2023, 04:47 pm »
Freo-1:
Did you try them without the sub?
How low do they go on their own?
Don
mresseguie
Re: ATC SCM 40 V2
« Reply #5 on: 14 Aug 2023, 04:50 pm »
I hope I can someday listen to a pair in my home. Thank you for your impressions.
Freo-1
Re: ATC SCM 40 V2
« Reply #6 on: 14 Aug 2023, 04:56 pm »
Freo-1:
Don
Hi Don,
Sure have.  Without Speaker Active Matching, the bass gets down to the low 40's without the sub.  Because it's infinite baffle, the bass is more extended over a bass reflex ported setup.
With SAM, they really go low.  The following link is provided to explain more:
https://www.devialet.com/en-ca/expert-pro-sam-ready-speakers/atc/scm40-mkii/
Re: ATC SCM 40 V2
« Reply #7 on: 14 Aug 2023, 06:16 pm »
You mentioned that they are infinite baffle.  In what way?  They look like regular sealed tower speakers based on a quick image search.
Freo-1
Re: ATC SCM 40 V2
« Reply #8 on: 14 Aug 2023, 07:15 pm »
From a quick internet search:
The infinite baffle speaker system is basically a closed box or cabinet. Which absorbs the rearward sound wave. The box is sealed to prevent as much sound emanating from the box as possible and it should also be made from solid material so that vibrations of the panels are reduced as much as possible.
Re: ATC SCM 40 V2
« Reply #9 on: 15 Aug 2023, 12:59 pm »
Infinite baffle mathematically refers to a rear firing space that is at least 10 times the driver's rated Vas.
Freo-1
Re: ATC SCM 40 V2
« Reply #10 on: 15 Aug 2023, 01:13 pm »
I think the SCM 40 fits that bill.
opnly bafld
Re: ATC SCM 40 V2
« Reply #11 on: 15 Aug 2023, 02:17 pm »
Infinite baffle can be either, the British in particular often refer to sealed speakers as infinite baffle.
If someone uses the term infinite baffle subwoofer, it is assumed they are referring to what JLM describes or at least a massive backwave air space close to 10 times vas.
Freo-1
Re: ATC SCM 40 V2
« Reply #12 on: 2 Nov 2023, 05:07 pm »
Posting an update:
It took some time to break in, but by mid to late October, the speakers have really opened up.  They sound quite a bit better than when I first started playing music on them.  I thought they were excellent out of the box, but they really sound remarkable now that they have broken in.
I was always a bit skeptical about equipment break in, but have been reliably informed that new speakers in fact do need time to break in to sound their best.  This is especially true with the ATC drivers.
They do need power to open up.  A pair of 90 watt tube monoblocks drives them very well, and sounds awesome with older blues/jazz recordings.  The ATC's sound their best playing large scale orchestra music with a Devialet Expert Pro 1000.
If one is in the market for speakers, these are a strong candidate.  Most highly recommended for audition.
