SOLD: Focal Dôme Flax compact audiophile satellites, white, $731
0 Members and 1 Guest are viewing this topic. Read 830 times.
taloyd
A good friend purchased these to put together a 5.1 home theater system during the first year of COVID and ended up sticking to a 2.1 system, as there wasn't room in his condo to place the other 3 speakers well enough to do them justice. He purchased them to match his ($1,400 each) Aria 926 floorstanding speakers, as they use the same technology (Flax) drivers.
Unfortunately he tossed the boxes for these. Which is a shame, as he never ever even used them - they're completely mint, unused, new. And beautiful - angled aluminum enclosures, flat white. Gorgeous.
They go for $689 each on Crutchfield (which is backordered). Have them here for basically that amount for BOTH.
Reviews are overwhelmingly positive.
https://www.avsforum.com/threads/focal-dome-flax-5-1-channel-speaker-system-review.3015380/
https://www.soundstageaccess.com/index.php/equipment-reviews/1048-focal-dome-flax-pack-512-home-theater-speaker-system
https://hometheaterreview.com/focal-dme-flax-512-speaker-system-reviewed/
https://www.whathifi.com/focal/dome-51/review
https://www.soundandvision.com/content/focal-dome-flax-51-speaker-system-review
https://www.digitaltrends.com/home-theater/focal-dome-flax-51-review/
Focal page:
https://www.focal.com/us/home-theater/dome/dome-flax
Specifications:
Dôme Flax
Type 2-way compact sealed speaker
Drivers 4" (10cm) Flax mid-bass
1" (25mm) Al/Mg inverted dome tweeter
Frequency response (±3dB) 80Hz - 28kHz
Low frequency point (-6dB) 72Hz
Sensitivity (2.83V/1m) 88dB
Nominal impedance 8 Ohms
Minimum impedance 4 Ohms
Crossover frequency 2500Hz
Recommended amplifier power 25 - 100W
Dimensions (HxWxD) 6 3/4 x 5 11/16 x 5 5/8
Focal PDF spec sheet:
https://www.focal.com/sites/www.focal.fr/files/shared/catalog/document/dome_flax_10-specification_sheet.pdf.pdf
Crutchfield page:
https://www.crutchfield.com/S-Xacqml3vENy/p_091DFW/Focal-Dome-Flax-White.html?XVINQ=GZ0&XVVer=11AL&awcr=628033641585&awdv=m&awnw=g&awug=9031118&awkw=pla-1831258674910&awmt=&awat=pla&gclid=Cj0KCQjwtamlBhD3ARIsAARoaEzSizkAKjDyZU2M6VtWaS4FQn2YRzp1F9Ec9jfTSe6dOBHDis52mzoaAiK4EALw_wcB
« Last Edit: 6 Sep 2023, 11:27 pm by taloyd »
taloyd
Sold; thanks all!
