Industry Circles
GR Research
Danny Richie
X-CS Bravo Center Kit
0 Members and 1 Guest are viewing this topic. Read 1268 times.
meng
2 Aug 2023, 07:13 pm »
Hi everyone getting started on diy speakers any info would be appreciated. How can I adjust crossover to roll at 12db at 120hz to match my sub or do I just build a high pass filter. Thank clueless here I believe I have a link to calculator for high pass filter. Or is it just best to do it all in my preamp.
Danny Richie
Facilitator
ยป
Re: X-CS Bravo Center Kit
3 Aug 2023, 03:57 pm »
Check this video:
https://youtu.be/65eFr2rKy3M
I would also recommend a lower target crossing over point.
meng
Reply #2 on:
25 May 2024, 02:22 am »
Thanks Danny I emailed you guys and you folks got back to quickly and was very helpful. Will start to build this kit finally, just got done with subs saving for decent amps to drive them.
AK-Grwn_v2
Reply #3 on:
26 May 2024, 05:50 am »
Out of curiousity are you running the center kit as the center channel or are you running two as left and right?
Industry Circles
GR Research
Danny Richie
