Amplifier Pass Labs versus Parasound JC5
0 Members and 1 Guest are viewing this topic. Read 1647 times.
Razor15
« on: 31 Jul 2023, 01:14 pm »
Hello... I am new to Audio Circle, looks like a great forum.
I am building out my Audio system and looking for an amplifier.  Currently looking at Parasound's JC-5 and Pass Labs Mono Blocks.  Heat is a consideration as I live in the SE.  I like the Class-A sound.  I currently own DynAudio Heritage Specials from what I can determine is they require higher current.
Any thoughts would be much appreciated
kd4ylq
  • Esse Quam Videri
Re: Amplifier Pass Labs versus Parasound JC5
« Reply #1 on: 31 Jul 2023, 08:53 pm »
If heat is a serious problem, as well as the potential need for much higher peak output current capability, you might want to run class D power amplifiers in the summer months. There is a pretty good selection of them now with at least decent sound, most at pretty affordable prices compared to the top rung class A or AB amps you are considering. When the weather turns cold, switch over to your high-power class A or AB amps and let them help you heat the house. I used variations of this scheme for many years and was quite happy with it. Just a quick alternative idea to consider - good luck finding a satisfactory compromise!
Phil A
« Reply #2 on: 31 Jul 2023, 10:04 pm »
Welcome!
I.Greyhound Fan
« Reply #3 on: 1 Aug 2023, 12:00 am »
If heat is an issue, go with the JC5 although both will get hot, the JC will be the lesser of the 2 evils.  I own a Pass X250 and previously owed a Halo A21.  The Halo only got warm but the Pass gets hot.  Pass gear is very dynamic and has slightly rounded and slower bass than the Parasound.  If you like hyper detail don't go with Pass.
« Reply #4 on: 2 Aug 2023, 05:43 am »
Greetings & Welcome to AC   :thumb:
GentleBender
« Reply #5 on: 2 Aug 2023, 08:24 am »
You may want to check out what Odyssey Audio has to offer. Klaus builds some great stuff that typically only gets warm, unless you really push them.
Infidel
« Reply #6 on: 2 Aug 2023, 10:00 am »
I looked at both too. Hopefully the JC5 will ship today.
« Reply #7 on: 2 Aug 2023, 04:29 pm »
Since heat is a concern I would recommend a good Class D amp.
rollo
  • Rollo Audio Consulting -
« Reply #8 on: 2 Aug 2023, 06:30 pm »
  Parasound gets my vote. However look at LSA Warp-1 and Benchmark. . Not a Dealer for them.
charles
