FS Ladder Bach R2R Preamplifier
0 Members and 1 Guest are viewing this topic. Read 4333 times.
Rivalaudio
« on: 27 Jul 2023, 06:48 pm »
Brand new, in box, never been used! I had intended to use this preamp in a second system that never happened. My loss, your gain. Street price is $899
I will let this guy go for a crazy $650 shipped US, or best offer!
Info:
LADDER BACH is a fully balanced HiFi pre-amplifier designed especially for high-end desktop chains. It features an R2R Based architecture that ensures pure sound performance with ample amplification and noise-free pure sound signal transmission. It is designed to bring top-tier quality performance to your desktop chains!! With its R2R-based ladder array network, enables constant impedance output with fewer fluctuations. It ensures you get crisp lossless sound quality performance with low signal loss during transmission. LADDER Bach is equipped with a powerful single-crystal copper transformer that provides quantitative sound performance for your audio chains. It enables powerful signal amplification resulting in improved performance of your desktop chains. Ladder has equipped the Bach with their in-house developed power supply that provides clean and interrupted power to different components on the audio chain. Ladder Back comes equipped with two sets of balanced input ports(XLR) and a set of single-ended input ports(RCA). As for the output, you get a balanced XLR and single-ended RCA output ports. LADDER Bach is a simply designed elegant-looking device that packs a solid frame and a solid performance. It features solid metallic chassis that not only gives it a simple and solid build but also protects the circuitry from electromagnetic or other interferences.
Rivalaudio
Re: FS Ladder Bach R2R Preamplifier
« Reply #1 on: 4 Aug 2023, 04:39 pm »
Price drop to $600!
Rivalaudio
« Reply #2 on: 14 Aug 2023, 08:06 pm »
Dropping to $500!
« Last Edit: 15 Aug 2023, 08:23 pm by Rivalaudio »
Rivalaudio
« Reply #3 on: 15 Aug 2023, 08:23 pm »
$475!
Rivalaudio
« Reply #4 on: 17 Aug 2023, 01:21 pm »
$450 folks! Seriously?!
Rivalaudio
« Reply #5 on: 25 Aug 2023, 01:41 pm »
Final and firm drop to $400. This is ridiculous folks.
MT POCKETS
« Reply #6 on: 26 Aug 2023, 11:14 am »
PM sent
williamjay
« Reply #7 on: 7 Feb 2024, 01:15 am »
Hello Rivalaudio,
Is this still available by any chance?
Thank you.
Sincerely,
Williamjay
