Digital Lock
0 Members and 1 Guest are viewing this topic. Read 3802 times.
Skyhawk
Digital Lock
« on: 27 Apr 2005, 12:53 am »
Good evening Folks
I know there is a discrete code I can send to the SP1.7 that will force it to stay in digital all the time instead of flipping to analog everytime I change the channel on my satellite system.
Anyone know what this is?
Skyhawk
Found It
« Reply #1 on: 27 Apr 2005, 12:59 am »
Found it
The Code is
Code Mute, Stereo, DTS - Dig Force On!!
No looking for analog now.  Little faster when switch channels now.  Still goes red though.  thought it would stay green.
Oh well.
nicolasb
Digital Lock
« Reply #2 on: 27 Apr 2005, 09:43 am »
It'll go red because whatever is producing the digital signal stops producing it! What the "lock" does is prevent the SP1.7 from switching into analogue mode when it loses the digital input signal. (If it did, it would take longer to switch back to digital mode when the signal comes back up).
Skyhawk
Comes Back Faster
« Reply #3 on: 27 Apr 2005, 12:00 pm »
Since I enabled the digital lock I found that audio comes back alot faster.  and the relays dont make quite as much noise
thxultra
Digital Lock
« Reply #4 on: 27 Apr 2005, 12:01 pm »
On a similair note does anyones sp1.7 when playing a dvd switch to pcm 48k when the DD/DTS signal dissapears ie.when  theres a layer change or when you select a diffrent menu on the dvd.
Also when it does this theres alot of clicking of relays which can be a bit obtrusive when watching a film.
brucek
Digital Lock
« Reply #5 on: 15 Jan 2006, 04:29 pm »
Does anyone know if the SP1 was ever programmed to allow this feature?
Perhaps there is a newer firmware release than mine = V19.0 (DSP 6.20)
James?
brucek
  • The Demo is Everything!
    • http://www.bryston.com
Digital Lock
« Reply #6 on: 15 Jan 2006, 05:38 pm »
Hi Bruce,
Yes it is a feature with the SP1.7 and SP2 only.
james
thxultra
Digital Lock
« Reply #7 on: 15 Jan 2006, 08:55 pm »
Quote from: James Tanner
Hi Bruce,
james
Is this the reason why my sp1.7 digital lock doesnt work as it used to be a sp1.
Digital Lock
« Reply #8 on: 15 Jan 2006, 09:17 pm »
Hi thx,
No if it is an SP1.7 update it should work.
Have you tried the code?
james
jethro
Digital Lock
« Reply #9 on: 15 Jan 2006, 09:20 pm »
thxultra,
I think you need version 44a software for this feature.
Digital Lock
« Reply #10 on: 15 Jan 2006, 09:40 pm »
Good point Jethro.
james
thxultra
Digital Lock
« Reply #11 on: 15 Jan 2006, 11:06 pm »
Quote from: jethro
thxultra,
Im running version 44D , any other suggestions  :cry:
Digital Lock
« Reply #12 on: 16 Jan 2006, 12:27 am »
What code are you using and how are you applying it?
james
MattH
Digital Lock
« Reply #13 on: 16 Jan 2006, 11:02 am »
Still not working thx ?
Does it say digital lock on when you apply the code ?
Cheers
Matt
thxultra
Digital Lock
« Reply #14 on: 16 Jan 2006, 01:22 pm »
The code im using is mute , stereo , thx which then says DIG.FORCE ON
Didn't realize it wasn't  working as i thought all the relay noise was just something brystons did.
It wasn't till MattH got his unit i realized something was up.
Would upgrading to a sp2 cure this problem James.
Digital Lock
« Reply #15 on: 16 Jan 2006, 01:45 pm »
You will still have some relay noise -- it is just that the digital light will not go RED then Green and the display will not say digital-analog- digital when you switch because it is not looking for analog (red light).
Yes the SP2 has a much faster microprocessor board and the switching relay noise goes away.
james
MattH
Digital Lock
« Reply #16 on: 16 Jan 2006, 01:54 pm »
Is there not a way to do a full reset of the processor.. I just wonder if it needs a "reboot" if thats possible..
Wasn't yours a upgrade from the SP1 as well....Was anything left of the SP1 after the SP1.7 upgrade.??
Cheers
Matt
thxultra
Digital Lock
« Reply #17 on: 16 Jan 2006, 02:17 pm »
I get the exact same amount of relay noise whether  the dig force is on or off
The digital light stays green on both occasions.
The display also goes from showing a digital signal to pcm 48k the back to a digital signal whether  the dig force is on or not
Is there some sort of reboot james
thxultra
Digital Lock
« Reply #18 on: 16 Jan 2006, 07:31 pm »
Just notice that when it switchs back and forth the mode lights up on the front panel aswell
Digital Lock
« Reply #19 on: 17 Jan 2006, 12:23 am »
Hi THX,
Have pasted this on to Mike Pickett for comment.
james
