Router Circle Jig Recommendations
0 Members and 1 Guest are viewing this topic. Read 704 times.
AndrewDIY
« on: 21 Jul 2023, 05:23 pm »
I have a BOSCH PR20EVS palm router. And I am a novice. Any recommendations for a good circle jig? Tips? Thank you!
mlundy57
Re: Router Circle Jig Recommendations
« Reply #1 on: 21 Jul 2023, 06:28 pm »
I like Jasper circle jigs but you can easily make your own for specific applications. Jaspers are a little pricy but save  lot of time
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #2 on: 21 Jul 2023, 06:32 pm »
Is that a 1/4 inch? I use jasper too... but if you use the same hole a lot it can get a little bit worn on there, adding some play...
AndrewDIY
« Reply #3 on: 21 Jul 2023, 07:32 pm »
Yes, this model has a 1/4 inch shank. And thank you both for the suggestions; I will likely get the Jasper. I am so excited to finally get into box building.
