Tube pre-amp impedance
0 Members and 1 Guest are viewing this topic. Read 1223 times.
bunkertoy
« on: 21 Jul 2023, 05:16 pm »
Hi all,
I was reading on a previous thread about solid state amp impedance with a tube pre amp. I do believe normally you shoot for 100 X 1 from tube pre amps. Like a 400 ohms pre amp impedance is fine with a 50K ohms solid state amp.
My Bryston 3B cubed is 50K ohms (I believe)
50k ohms for single ended, but only 10k ohms for balanced. does that mean that a tube pre with 400ohms impedance is not a match if connected to balanced ?
I was looking to match a Cary SLP-05 with my bryston 3B cubed. I really wanted to connect via balanced connections.
Can any one supply some thoughts on this match up ?
Thks in advance for your input.
Cheers
opnly bafld
Re: Tube pre-amp impedance
« Reply #1 on: 21 Jul 2023, 06:10 pm »
Ask this in the Bryston circle or email them.
Input Impedance:   Unbalanced 7.5kΩ
                             Balanced 30kΩ+ / 6kΩ-    :scratch:
10 to 1 is usually considered the minimum.
richidoo
« Reply #2 on: 22 Jul 2023, 04:06 pm »
That preamp is a fully differential design with 3 or 4 6SN7s per side, iirc; one of the most glorious sounding preamps I've heard, and Dennis Had's greatest masterpiece, imo.
400 ohms Zout is very good for a tube preamp. It will have no problem driving your 10k balanced input with 1:25 impedance ratio, as the 6SN7 tubes are somewhat decent current source.
I heard it driving 250k Zin differential tube amps. Since 3B is not a true differential amplifier then you may be pleasantly surprised hearing SLP-05 driving a similarly "ultra high end" differential amp.
bunkertoy
« Reply #3 on: 30 Jul 2023, 06:38 pm »
Thanks so much for you insight. That is the exact info I was hoping to find.
Cheers
