0 Members and 1 Guest are viewing this topic. Read 2894 times.
But why would it matter in a hi-fi rig? I'm going to take a guess and say the Mullard has a faster 'recovery' than the GE, so the exact opposite of the sag effect......it's letting more of the detail come through. Seems plausible , but I don't much about.....well anything to tell the truth.
But tube brand aside, I'm can not figure out why changing the rectifier would be audible. I know some rock guitarist like tube rectified preamp sections because it can add what is called 'sag' which I take adds a bit of compression to get those nice creamy lead tones. But why would it matter in a hi-fi rig? I'm going to take a guess and say the Mullard has a faster 'recovery' than the GE, so the exact opposite of the sag effect......it's letting more of the detail come through. Seems plausible , but I don't much about.....well anything to tell the truth. So if that theory is correct......why a tube rectified version at all.....that was more expensive than the SS version? There has to be a sonic reason. ($42 for the tube shipped NOS in original box)
I think there are two ways that the rectifier tube can change the sound. Tube rectifiers have a considerable voltage drop compared to silicon diodes, and this voltage drop can vary considerably from one tube to the next. This difference subtly changes the operating points of the tubes in the audio circuit (assuming no active voltage regulation). In addition, the voltage drop changes with load, so some tubes will have more or less sag as the audio signal changes.
