Neumi CS5 - 4x Inductor Crossover Layout
0 Members and 1 Guest are viewing this topic. Read 826 times.
krjohnson29
« on: 12 Jul 2023, 03:23 am »
Hi all,
I got a kit for the Neumi CS5 center channel and I'm starting to lay it out. The challenge I'm having with this one is that there are FOUR inductors that have to fit in this relatively small speaker.
There's about a 14" x 7.5" space inside the speaker I have to work with, and since the drivers are 5" the boards need to be ~4" wide to fit through the holes. So I'm thinking of laying it out on three 4" x 4" boards (one for the woofer, the other two tied together for the tweeter). But I'm wondering what the best layout is to keep the inductors properly spaced and oriented.
This is what I've come up with, what do you think? Is there a better way to orient/space the inductors?
Thanks for your feedback! :)
Danny Richie
    • http://www.gr-research.com
Re: Neumi CS5 - 4x Inductor Crossover Layout
« Reply #1 on: 12 Jul 2023, 10:27 pm »
You inductor spacing is fine.
