FS: ifi Micro iDAC2
0 Members and 1 Guest are viewing this topic. Read 830 times.
BRN
FS: ifi Micro iDAC2
« on: 10 Jul 2023, 07:04 pm »
For sale is my iDAC2. It includes the box and everything that came with the DAC. I never even put the rubber feet on it. It is is great shape and looks and works like new.
Asking $175.00 plus shipping and 3% PP fees. Ships from 20175.
This is a full featured DAC for home use. This was my main DAC for many years and now it is time to pass it on to someone that can enjoy it.
Specifications:
Input:                       USB3.0 (USB2.0 compatible)
Output:                     SPDIF RCA (only PCM up to 192KHz)
                                Audio RCA
                                3.5mm Headphone
Formats:                   44.1/48/88.2/96/176.4/192/384KHz PCM
                                2.8/3.1/5.6/6.2/11.2/12.4MHz DSD
                                353/384KHz DXD
DAC:                         Bit-Perfect DSD & DXD DAC by Burr Brown
                                (1-DAC Chip; 2-Channel; 4-Signals)
Filters:                      PCM: Bit-Perfect/Minimum Phase/Standard, Digital filters selectable
                                DSD: Extreme/Extended/Standard, Analogue filters selectable
                                DXD: Bit-Perfect Processing, Fixed Analogue filter
Line Section
Output:                     2.1V (+/-0.05V) fixed
Zout:                        < 39 Ohm
SNR:                         > 114dB(A) @ 0dBFS
THD+N:                    < 0.0025% @ 0dBFS (100k Load)
                                < 0.025% @ 0dBFS (600R Load)
Headphone Section
Output:                     > 350mW (2.40V) into 16R (<10% THD+N)
                                > 34mW (3.20V) into 300R (< 0.1% THD+N)
Output Impedance (Zout):   < 2 Ω
THD+N:                    < 0.0025% (1V into 16 Ohm, 0dBFS)
SNR:                         > 114dBA (3.2V into 16 Ohm, 0dBFS)
Power consumption:   <1.5W
Dimensions:              158(l)x68(w)x28(h)mm
Weight:                     265g(0.58 lbs)
The full details can be found on the ifi Audio web site at https://ifi-audio.com/products/micro-idac2/.
« Last Edit: 14 Jul 2023, 01:07 pm by BRN »
