Build Subwoofer into Victor Projector speaker box
0 Members and 1 Guest are viewing this topic. Read 1375 times.
sglaab
« on: 7 Jul 2023, 10:57 pm »
So this prokjector speaker box is about 18" x 18" and the speaker diameter is ~10"
Can I build a subwoofer?  How would you do it?
Re: Build Subwoofer into Victor Projector speaker box
« Reply #1 on: 15 Jul 2023, 01:49 am »
First: I wouldn't destroy a vintage speaker like that.
Second: It probably wouldn't be hard to swap a driver, but you need a driver that would physically fit as well as have enough airspace.
Third: Not sure if the box would need extra work to make it useable.
Forth: It probably could "work", but it would be more a novelty item. A half-way decent powered subwoofer would be a better option.
