Eddie Current Aficionado - vacuum tube headphone/ speaker amplifier amp
0 Members and 1 Guest are viewing this topic. Read 564 times.
ccie8030
Up for sale is hard to find tube amplifier
Low hours and usage. Have driven every headphone I threw at it.
posted on usaudiomart - https://www.usaudiomart.com/details/649999463-eddie-current-aficionado-vacuum-tube-headphone-speaker-amplifier-amp/
head-fi.org - https://www.head-fi.org/classifieds/eddie-current-aficionado-vacuum-tube-headphone-speaker-amplifier-amp.50450/
asking price is $2200.00 plus shipping/insurance
FEATURES:
Balanced and single-ended inputs
4 pin XLR outs for headphones
Speakon speaker outs (3.5W for efficient speakers)
Balanced and SE pre-outs
EXTRAS:
1 Matched pair EML Mesh 2A3 Output tubes (bought new for $728)
(2) WE 396A, (1)LM Ericsson 2C51/396A input tubes (a $150 value)
1 Mullard Metal Metal base GZ-34 rectifier tube (bought for $295)
Coupling caps upgraded to Jupiter copper foil
Cathode caps in driver and output stage upgraded to Nichion KZ (for lower ESR &faster transients)
Transformer covers
Output Tube sockets turned 180 degrees to make them face forward (w/ stock configuration the EML logo was to the back)
CineMag output transformers with tertiary winding.
Balanced headphone drive.
Two input selector switch, one pair XLR Balanced inputs, one pair RCA unbalanced inputs.
Speaker kill switch.
100K high Alps blue Velvet volume control.
One pair Speak-On speaker outputs.
4-foot detachable umbilical cord.
Hand wired point to point signal circuit.
Vacuum tube rectified passive LC power supply.
Will drive 8 ohm speakers to 4 watts. Input sensitivity 1.5V for full power.
Power bandwidth -1dB 10Hz-25kHz.
Recommended headphone load 8 ohms or higher.
Power into 32 ohms 2W.
Power into 100 ohms 800mW
Power into 300 ohms 400mW.
Typical headphone frequency response -1dB 15Hz-30kHz.
Balanced line output 11 volts into 600 ohms. -1dB 15Hz-30kHz.
Unbalanced output 0.5V for 3.25V output -1dB 12Hz-35kHz.
ccie8030
this is sold!
