Recommend reading Floyd Toole's "Sound Reproduction" (either edition) to learn how bass reacts in rooms. Unfortunately he suggests using 3 or 4 subs, located either in the corners or midway along each wall. According to Toole your small square room should be a bass disaster with bass reinforced from all three primary directions at roughly 95 Hz. I tried auditioning loudspeakers in an 11 ft glass cube (at an audio dealer) years ago. The effect was horrible, triple reinforcement at 100 Hz.
You are exactly right. This is why I like open baffle subs plus EQ. They remove the side to side mode entirely via physics and then EQ can clean up the other modes pretty easily.
If you use one sub try in between the speakers. If two in corners. Then listen, you will know. Maybe try a speaker that goes down lower in lieu of sub.charles
I was thinking about getting new speakers that can go lower. I've been looking for a reason to try Zu DW6's. If I still need a sub, GR R open doubles never entered my realm of possibilities in my small office. Seems like many options. Customer service goes a long way with me. I've had great experiences with GR R & SVS. If I have to grab a sub I'll probably end up with one of those two.
Which is why I mentioned the SVS Cylinder option. Great for smaller rooms, takes up less space, great performance.
...Thus, initially I was considering 2 subs but I don't know if 2 are necessary. ...
