Swan Diva 6.1 and C3 Speakers (Southern California)
0 Members and 1 Guest are viewing this topic. Read 1219 times.
SteveSatch
« on: 22 Jun 2023, 04:05 pm »
Swan Diva 6.1 main speakers and Swan C3 center speaker.  Never used.  6.1 are out of the boxes and C3 is in the box.  $600 for the 6.1 and $200 for the C3.
Swans Diva 6.1 Tower Loudspeakers
Specifications
3-way, 4-driver system, 4th-order vented alignment
Frequency response: 33Hz-20kHz
Efficiency: 90 dB
Nominal impedance: 8 ohm
Power handling: 20-300 watts
Dimensions (W × D × H): 11.75 × 15.2 × 41.25 in
Weight: 71.5 lbs each
Swan C3 Center Speaker:
Specifications
150W
Tweeter: 28mm Danish-style silk dome.
Midrange: 50mm silk dome w/Neodymium motor.
Woofer: 2×6.5" aluminum/magnesium alloy inverted dome.
Home Theatre series 2th-order,3-way sealed-box sys
Dimensions:2 2.9" x 10.0" x 10.4"
Weight: 33.1 lbs.
