Spotify Hi-Fi certainly nearly here, probably..
0 Members and 1 Guest are viewing this topic. Read 1439 times.
aricml
« on: 20 Jun 2023, 08:30 pm »
If Spotify truly is finally rolling out lossless would you try it?  Or is it simply too late to the table to eat supper?
GentleBender
Re: Spotify Hi-Fi certainly nearly here, probably..
« Reply #1 on: 20 Jun 2023, 09:06 pm »
I would definitely try it. I like their GUI better than the other options.
jpm
« Reply #2 on: 20 Jun 2023, 09:41 pm »
Not unless they integrate with Roon.
won ton on
« Reply #3 on: 20 Jun 2023, 10:20 pm »
So what is GUI ?
GeneS
« Reply #4 on: 21 Jun 2023, 01:13 am »
So what is GUI ?
I believe, in this case, that it stands for Graphic User Interface. Like, the thing you use and see to play music.
In answer to the OP’s original question, I’d likely try it. I’ve begun shopping around for a new streaming music service. I currently have Tidal because of MQA. But if that goes by the wayside, I don’t need Tidal anymore. Anything high rez will work, and Spotify may be just fine. Or Apple, or Amazon, or…..
And I could easily dump Roon. They’ve become something I don’t recognize. And all that means I could change out my DAC (won’t need a renderer).
Oh! The possibilities are endless!!! :lol:
won ton on
« Reply #5 on: 21 Jun 2023, 09:20 am »
GeneS       thanks for the reply
