Poll
What is a good look for rounded corners on X-LS Encore 1/4 or 1/2 inch.
1/4 inch round over
0 (0%)
1/2 inch roundover
7 (100%)
Total Members Voted: 7
Speaker Build
0 Members and 1 Guest are viewing this topic. Read 1126 times.
tino95843
Speaker Build
« on: 16 Jun 2023, 12:23 am »
Not sure which corner to go with.
Re: Speaker Build
« Reply #1 on: 16 Jun 2023, 03:32 pm »
Bigger the better for performance, but that cuts into material thickness of the panels and strength of the joints.
JCarney
Re: Speaker Build
« Reply #2 on: 16 Jun 2023, 03:42 pm »
Routing the edges will help prevent the sharp corner from fracturing if there is an accident. The rounded edge also helps with refraction of the drivers on the sharp corners. Grab a scrap piece and do one side with the quarter inch round over, the other with the half inch round over and see which one you like the look of better.
JCarney
Re: Speaker Build
« Reply #3 on: 17 Jun 2023, 12:05 am »
I will move this topic to the GR Research Circle as You already introduced yourself in the Starting Block Circle.
KTS
Re: Speaker Build
« Reply #4 on: 17 Jun 2023, 12:31 pm »
I believe the 1/2” will give better performance and if you are veneering the front baffle and sides as one piece, it will be easer to make the 1/2” over the 1/4” in my opinion.
Kelly,
mlundy57
Re: Speaker Build
« Reply #5 on: 17 Jun 2023, 04:02 pm »
Danny recommends at least a 3/8" roundover.
g3rain1
Re: Speaker Build
« Reply #6 on: 17 Jun 2023, 04:59 pm »
Mike, what's the largest round over you can go before it weakens the corners too much? Assuming the standard 3/4" mdf.
Hobbsmeerkat
Re: Speaker Build
« Reply #7 on: 17 Jun 2023, 08:15 pm »
Danny's recommendation is 3/8" which is right in the middle of both 1/4" and 1/2"
But 1/2" will be fine. so long as you're using 3/4" MDF for your panels.
you can mitigate any weakness from 1/2" by adding small wedges to the corners, or adding additional glue along the inside edge (so long as the wedges don't interfere with the woofer cut out, which also needs 3/8" round-over on the inside edge)
