Roomie Remote with Bryston
0 Members and 1 Guest are viewing this topic. Read 826 times.
sep297
« on: 10 Jun 2023, 08:05 pm »
Hi,
I am currently looking at replacing my Logitech Harmony remote with probably a Roomie remote IOS application and assorted connections. I use a BR20 as a Roon endpoint and in Theatre Bypass and a BDA 3.14 where I use it with various inputs including HDMI but most of the time again it is just a Roon endpoint. I can buy the Itech IR kit and RS232 kit as well as control over IP.
What would be the most effective way with Bryston - avoiding IR if possible and I suppose IP first as it requires no additional hardware if the 'Devices' are avaialable?
If it is RS232 what cable do I need to get from the serial port on the Itech device to the Bryston gear?
Many Thanks In Advance
Stuart
Mariusz Uszynski
Re: Roomie Remote with Bryston
« Reply #1 on: 11 Jun 2023, 03:21 am »
Hi Stuart
I operate my Bryston BP-17³, 4B³, BCD-3 with URC MX-990.It is very elegant and modern remote control, but bit pricey and it had to programmed at the electronic store, where I purchased my MX-990.You may be able to do it yourself, if you are computer savvy, but you'll need URC software for it.I have seen guy doing it and it was not that easy.There is another one, URC MX-450, which is lot cheaper and you can program at home, old fashion way, two remotes facing each other, really easy.When I purchased my Bryston gear, for some diabolical reason, I was not able to transfer BCD-3 commands into MX-450, that why I had to purchase MX-990.You mentioned, you have BR-20 and BDA-3.14, so MX-990 would be your best bet.Good luck to you.
Mariusz.
https://www.urc-automation.com/product-category/complete-control/
« Last Edit: 11 Jun 2023, 10:34 am by Mariusz Uszynski »
sep297
« Reply #2 on: 1 Aug 2023, 03:54 pm »
Thanks Mariusz it did look interesting,
Although after a bit of research, I ended up going with Roomie and have got most things to work and have a workaround for the others. My Oppo, Trinnov, LGTV, shield, and apple TV are all included in the included library of commands. The rest of the setup is only slightly more complex than the Harmony to get those going.
However my BR20 and BDA3.14 are not in the included library of IP commands. So with my reasonably basic programming skills  I am trying to get the Bryston equipment to work over IP via the Service port, Adam has sent me the latest codes - the same hex as listed for the IR remotes. So I have populated a file with the commands via a Plist editor (example button below).
<key>HDMI1</key>
<string>006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 0049 000B 0049 000B 0049 000B 0049 000B 000B 0049 000B 0049 000B 0049 000B 029</string>
To get this to work I need to know which Port number they use as I already have the IP address of each service port.
I then need to know which type of connection it is, from these choices.
gc                 Global Caché Infrared Method (also supports Pronto Infrared Codes)
binary-ack     Binary TCP or Serial Method requiring a response before new data
binary           Binary TCP or Serial Method that does not require any response
lineio            TCP or Serial Method using text commands with CR line endings
lineio-crlf      TCP or Serial Method using text commands with CRLF line endings
http              HTTP Method including GET/POST, body, and header functionality
udp              UDP Method for sending raw UDP packets
rtsp              Live Video via RTSP over UDP
onkyo          Convenience to wrap simple Onkyo commands for Onkyo’s encodings
samsungdtv Samsung Packet Encoding
hk               HomeKit
sio               SocketIO
websocket   WebSockets
gcast           GoogleCast
Any Thoughts or pointers welcome!
Many Thanks
Stuart
