***SOLD***: Denafrips Terminator II 12th Anniversary Edition
0 Members and 1 Guest are viewing this topic. Read 806 times.
Early B.
***SOLD***
For sale is a Denafrips Terminator II 12th Anniversary version with high purity gold+silver+copper alloy AC transformers. The unit is in great condition with a couple of small, very minor scratches on top of the unit.
The Terminator II uses state-of-the-art fourth-generation discrete resistor 26Bit R-2R for PCM decoding, 6Bit DSD hardware decoding with 32 steps FIR filters, a total breakthrough of the traditional integrated chip constraints.
The DAC core conversion module R-2R is constructed with 0.005% high precision, 10ppm low thermal effect precision resistors. Each channel uses more than 500pcs of these precision resistors, or 1000pcs for two channels, it's 4 times more than the other typical R-2R DAC. These achieve a truly astonishing low distortion, full balanced design. Oven-controlled crystal oscillators OCXO clocks are used with FIFO buffer and reclocking - to eliminate the word-clock jitter from the sources.
Dedicated encapsulated beefy linear power supply unit, designed in a thick metal alloy enclosure, can be found underneath the DAC board with an additional steel plate divider between them for extra shielding. Other features include beefy, dual O-core transformers for digital and analog sections, ultra-low ESR, long endurance reservoir capacitors, and a multi-stage super linear power supply which ensures ultra-precision.
Price is $4,150 including shipping in USA. Will ship in original box.
« Last Edit: 3 Jun 2023, 10:26 pm by Early B. »
richidoo
Re: FS: Denafrips Terminator II 12th Anniversary Edition
« Reply #1 on: 3 Jun 2023, 07:20 pm »
wow sexy  8)
Love my termy!
