sold: Technics SL-1200GR
0 Members and 1 Guest are viewing this topic. Read 1056 times.
dvzzz
« on: 24 May 2023, 02:33 am »
Spec:
Fusing Technics’ traditional analog and digital technologies, the SL-1200GR is the new standard in direct drive turntable systems. With a newly developed coreless direct-drive motor and precise motor control technology that eliminates cogging from rotation irregularity, plus a low-vibration, high-rigidity platter and high-sensitivity tonearm, the SL-1200GR outperforms the usual standards of its class, for rich, robust sounds and true high-fidelity listening.
Newly developed coreless direct-drive motor with no iron core eliminates cogging
Advanced motor control technology for high starting torque and high-speed stability.
Three-layer turntable construction with deadening rubber to eliminate unnecessary resonance
The balance of the turntable is adjusted at the factory using specialized high-precision equipment
High-sensitivity tonearm with lightweight magnesium for a high damping effect
« Last Edit: 14 Jun 2023, 08:49 pm by dvzzz »
Rocket
Hi,
I had one of these turntables and its pretty good. I upgraded it to a Technics SL1200G and personally I don't hear any difference.
Good luck with the sale.
Cheers Rod
