FS: Clearwave Symphonia speakers - Accuton Cell & Scan-Speak - Georgia
0 Members and 1 Guest are viewing this topic. Read 1746 times.
Krillin
Asking $3,000
Evans/Augusta, GA 30809 local pickup
The cost of the raw parts has gone up thanks to Bidenomics:
Accuton Cell C25-6-158: $554 each
Accuton Cell C90-6-724: $742 each
Scanspeak Illuminator 18WU/4747T-00: $356 each​
Raw cost of parts is $3,304 plus tax, crossover parts and cabinetry if you were to build these yourselves. This is also a commercial product and not a DIY project.
Clearwave Symphonia
Accuton Cell c25-6-158 - Hificompass - https://hificompass.com/en/speakers/measurements/accuton/accuton-c25-6-158-cell
Accuton Cell C90-6-724 - Hificompass - https://hificompass.com/en/speakers/measurements/accuton/accuton-c90-6-724
Scan-speak Illuminator 18wu-4747T00 VoiceCoil Review - https://www.scan-speak.dk/datasheet/reviews/18WU-4747T00-VoiceCoil_2010-4.pdf
The woofer has an impressive Klippel verified 10mm xmax. The C90-6-724 inverted dome midrange is HiFiCompass's favorite Accuton midrange.
Here's the list of features:
    Made in the USA cabinetry
    German top of the line driver technology
    Accuton Cell midrange/tweeter array
    Low parts count crossover
    ERSE air core inductors
    Mundorf capacitors and resistors in tweeter signal path
    Mundorf resistors
    Cardas soldering all point to point from binding posts to drivers
    High-end Supra wiring
    Cardas patented binding posts
    Custom engraved binding post plate and port ring to lower resonance.
    Braced baffle and sidewall technology
    Flared port for low noise
    Proprietary damping material to turn vibration into heat
    Size: 8.25"W X 35"H X 11.5" D (cabinet tapers back and slopes 5 degrees)
    Frequency Response: 38hz-25khz
    Minimum Power Requirements: 35watt (tube) 50watt (solid state). 86db/2.83v/meter
    3-way fullrange loudspeaker
    Tweeter/midrange array decoupled by expanding o-ring driver technology mounted to custom aluminum mounting plate
    1 x 25 mm Accuton Cell ceramic tweeter
    1 x 90 mm Accuton Cell ceramic midrange
    1 x 184 mm Illuminator woofer, long excursion design with under-hung voicecoil
    Bassreflex port design for lowest port noise with dual flared ends.
    Height adjustable isolation outriggers
    impedance: 4 ohm (lowest point: 3.1 ohm at 100Hz)
    Standard veneers include: Cherry, Walnut, Ebony (faux)
    Weight: 2 x 65 lbs. (plus packaging)
« Last Edit: 11 Sep 2023, 08:06 pm by Krillin »
Krillin
Open to offers
« Last Edit: 11 Sep 2023, 08:05 pm by Krillin »
Krillin
Still for sale
