Zesto bia and x5?
0 Members and 1 Guest are viewing this topic. Read 1535 times.
Jprod
Zesto bia and x5?
« on: 7 May 2023, 04:22 pm »
Hello. It has been a while since I posted.  I have the x5s and currently a decware Tori jr v2 which I have enjoyed.  As is the case in this hobby one is always looking for better / something different.  Anyone out there have any experience with the bia amps and Spatials ? Is it overkill for a high sensitivity speaker ?  Btw I have the Zesto andros deluxe 2 phonostage which is awesome
Any thoughts would be appreciated
Mr. Big
Re: Zesto bia and x5?
« Reply #1 on: 7 May 2023, 11:18 pm »
Heard the Zesto with the X series and it sounds superb, as far as power not to worry think of your headroom for dynamics, that matter, and why power is good.
Jprod
« Reply #2 on: 8 May 2023, 12:03 am »
Thanks for reply.  I with my bad back had sworn off big heavy amps but I’m sure tempted.
RonN5
« Reply #3 on: 8 May 2023, 01:04 am »
Since the amp doesn’t drive the woofer in the X… has the Tori 20 watts been sufficient… I suspect so meaning you have a ton of amp options.
Jprod
« Reply #4 on: 8 May 2023, 01:51 am »
Yes.  The Tori jr doesn’t run out of steam.
