HELP! Tweeter stops working after a few seconds to few minutes.
0 Members and 1 Guest are viewing this topic. Read 1394 times.
g3rain1
This just started happening in the last couple days after the speaker was working fine for several months. The tweeter on one of my NX-Oticas stops producing any sound at all after a few seconds to few minutes of playing audio through it.  It's not a gradual fade out, when it stops, it stops instantly. Playing at higher volume makes it stop sooner than playing it quietly. I don't think it's the crossover, but I'm not 100% sure on that. All the connections seem solid and moving/touching them seems to make no difference. Unplugging the speaker wire and plugging it back in usually fixes it.
Remove the tweeter and test it with a multimeter.
The speaker cable from the amp or the tweeter cable?
g3rain1
From the amp. The tweeter is soldered.
To test the tweeter voice coil you will have to desolder it, or unsolder at the crossover.
g3rain1
And once unsoldered what's the best way to test it?
Hobbsmeerkat
It's possible that the diaphragm has come loose from the internal contact, and as it heats up, it separates and fails abruptly then when it cools it makes contact again.
Just shoot us an email to [email protected] and we'll get you taken care of.
To know if the VC are open use a meter.
If the VC are broken the tweeter will not work.
As you said it came back to work you will have to peruse around.
g3rain1
Okay, thanks Hobs. Just sent it.
Many years ago I bought a Beyma 5MP60/N, it had a loose VC but the sound was good, I returned it to repair, unfortunately after the repair by the Beyma distributor the driver sound becomes no so good, the Harmonics content was so poor that I had listening fatigue after a few minutes and the plastic PP cone tone was audible in the midrange and treble.
Hobbsmeerkat
In cases like this we will just replaced the tweeters with a new matched pair. We dont have the tools to attempt a repair in house.
richidoo
If the tweeter itself was open circuit due to heat expansion of diaphragm breaking the diaphragm conductor then it should cool down when it stops playing and fix itself, turning on and off continuously. I'd love to see that! I don't think this phenomenon would last long since the diaphragm is so thin and delicate. But since it stays off until you disconnect the speaker cable, that suggests to me that something in the tweeter crossover is shorting to ground (electrically muting the tweeter) when heated, and the heating is sustained as long as current is applied. It doesn't cool down and stop shorting until after current is removed by disconnecting the SC.
A resistor is most suspect because resistor's job is to create heat but an internal short can be in any component. Feel if any tweeter crossover parts are warm to the touch when signal still being played after the tweeter goes quiet. If there's a short it should be warm. Turn volume up to normal-loudish level to enhance the heating so you can feel it. Do you have an IR camera?  :lol:
Astrologically, Mercury (and Pluto) are retrograde now, so things will break in the most confounding and unimaginable ways.
