0 Members and 1 Guest are viewing this topic. Read 4987 times.
It is sad to see a company as esteemed as Magnepan wasting their time 'solving' problems that were solved nearly fifty years ago by the late (and seemingly largely forgotten) Roy Allison, but the stated design objectives and and design approach and the form factor of this box suggest that is exactly what is happening. It all has to do with speaker driver relationships to room boundaries and crossover points. Biggest difference seems to be that this seems to be a lot of woofers to yield high power handling whereas the Allison systems were fullrange three-ways.Sometimes I wonder if the reason Allison's discoveries have been overlooked (maybe even ignored) by the audio industry in favor of multi sub configurations is that the industry makes money by selling boxes- the more boxes they get you to buy, the more money they make. Maybe that's why the simple solution gets short shrift.Allison One (1974)
The Allison Model 1 and Model 2 speaker were designed to be placed against the front wall. The Model 2 was a smaller version of the Model 1.The woofer had to be placed below the 1/4 wavelength distance at its upper frequency range from the floor to the listening height to minimize comb filtering interference in the lower ranges. Being against the wall makes the mirror image be at 0 distance to the woofers to reduce front wall interference. Frequency response was very even, but having a sound stage with depth was not part of the idea.
Yes, and minimize the floor bounce loss as well.
Planar enthusiasts,Been patiently waiting for these since the initial sneak,Any insights? preview.....https://www.theabsolutesound.com/articles/16-woofers-magnepan-ultra-wideband-bass-system-first-listen/
Wendel's been talking about a subwoofer longer than Elon Musks been flogging the Cybertruck -in both cases I ain't gonna start breathing heavy until I see one at a dealers for sale.
I never felt like I had a 'depth deficiency' if by 'depth' you mean actual depth cues present in recordings and not the impressions of depth added by room reflections not part of the original recording and the plethora of room effects that afflict this approach. Both of my Allisons (Model Four and CD8) sounded virtually the same anywhere in the room. (My friends who had them sounded pretty much the same as mine- in completely different rooms. Magnepan's approach appears related aside from the column-of-woofers design approach. It too will be subject to the same laws of physics every designer must wrangle with, and time will tell if it interfaces well (as essentially a 2.1 arrangement) with narrow-dispersion dipoles like the entire Maggie product line.
Did I read that correctly, they're expecting you to use two of them?
