A Flexible DIY Tube / Valve Tester
0 Members and 1 Guest are viewing this topic. Read 1008 times.
ieales
« on: 18 Apr 2023, 10:29 pm »
For too long, I wanted a tube / valve tester that could test under 'actual use' conditions, match sections on dual triodes and run power tubes at close to voltage and current in actual use.
Finally, I got off my duff and did it with many thanks to all the ideas extant.
It's easy to modify for various tubes or add a 'patch bay' and external adapters for almost any tube.
The circuity is on a PCB making robust, modifiable and repairable.
Schematic, BoM, CAD drawings, wiring sketches supplied.
I'm happy to assist with any questions.
https://ielogical.com/assets/Lab/ValveTester/index.php
Re: A Flexible DIY Tube / Valve Tester
« Reply #1 on: 18 Apr 2023, 10:54 pm »
Assembling a tube amp is difficult enough, mounting tube testers are more tough and dangerous than tube amps.
Ericus Rex
« Reply #2 on: 19 Apr 2023, 02:24 am »
Really cool!  I like what you've done with all the hi/lo toggles.  And it looks like it can be made quite affordably.  Well done!
jjss49
« Reply #3 on: 19 Apr 2023, 02:19 pm »
make me one!!!!  i couldn't solder if my life depended it on!!!  :lol:
ieales
« Reply #4 on: 20 Apr 2023, 05:24 pm »
About $350USD for all new parts. About $30 to $40 of that is extra shipping for stuff that could all be ordered at once from Mouser.
