NUPRIME STA 9X
0 Members and 1 Guest are viewing this topic. Read 519 times.
neb55
NUPRIME STA 9X
« on: 14 Apr 2023, 09:33 am »
Hello,
I’m a new member of this forum and thank you in advance for your support.
I own the following loudspeakers: ATC SCM11, ATC SCM19 and SONUS FABER Auditor M together with a network player LINDEMANN SOURCE II. My consideration is now to add a NUPRIME STA9X.  Does anyone
have experience regarding NUPRIME along with ATC and SONUS FABER.
Thanks in advance @ kind regards
Ben
Re: NUPRIME STA 9X
« Reply #1 on: 14 Apr 2023, 09:30 pm »
Welcome to AC  :thumb:
Re: NUPRIME STA 9X
« Reply #2 on: 15 Apr 2023, 03:07 am »
Greetings & Welcome to AC Ben   :thumb:
AllanS
Re: NUPRIME STA 9X
« Reply #3 on: 15 Apr 2023, 12:26 pm »
Welcome to AC!  Hopefully someone has the experience you are looking for.  If not Jason from NuPrime will likely chime in, but it may take a few days.
Now that you’ve introduced yourself you might also consider reposting your question to the NuPrime circle to improve chances that Jason or others who can help will see it.
