Amazing Brinkmann Balanced Turntable & Breuer Dynamics 8C MKii arm $15,350
0 Members and 1 Guest are viewing this topic. Read 1143 times.
findog3103
This is a fantastic turntable. Sounds amazing and recently recalibrated by Brinkmann technicians. Comes with the legendary Breuer Dynamic 8C tonearm, the one Brinkmann tonearms are modeled on. Asking $15350
Also includes RöNt I Power Supply, HRS Granite Turntable Base, and Record Clamp
Rated 8/10 for minor cosmetic wear consistent with age (about 13 years old) and use - still looks and works as it should - beautiful!
Specifications:
Drive: precision ground round belt
Dimensions (WxDxH): 550 x 400 x 140 mm
Weight: 33 kg
Platter: weight 18 kg, Ø 316 mm, height 90 mm.
Platter surface: planar polished crystal glass (recessed mounting)
Motor - RECALIBRATED LAST MONTH BY BRINKMANN TECHNICIAN and
NEW TURNTABLE BELT PURCHASED FROM BRINKMANN
Original Brinkmann Record Clamp
Breuer Dynamic Tonearm:
Model: 8C
Effective length: 249mm
Overhang: 17mm
Offset: 22 degrees
Mounting Distance: 231.4mm
VTA Adjust: Yes
Brinkmann RöNt I with granite base - RE-TUBED AND RECALIBRATED LAST MONTH BY BRINKMANN
Power consumption: ca. 80 Watts
Output voltage: stabilized to 24 ..25VDC
Output current: 0...500mA peak
Life time: more than 10.000 hours
Tubes: 2x PL36 , 1x BZ34 tube simulator
Dimensions: 180 x 65 (100) x 310 mm (WxHxD) (with granite)
Weight with granite: ca. 12 kg
HRS Isolation Base
Dimensions: 23” x 19” x 3”
Weight: approx. 23kg
Message me for any questions. I prefer pick-up or meet up as it is very heavy and will require at least four boxes to ship. I have the original platter wood box and HRS base wood crate.
More images available upon request.
Make me an offer.
« Last Edit: 29 Apr 2023, 10:31 pm by findog3103 »
