0 Members and 1 Guest are viewing this topic. Read 8975 times.
I saw a post somewhere (don’t remember where) where someone successfully used stands like you pictured. If I cone across it again I’ll post a link.
Thanks.edit: That's where I got the idea. That poster though, is in the Netherlands.
those who are handy, creative and resourceful can often diy something that has been commercialized by someone else and sold for a profit, and save $$ - but this only worth it if one's time is not better employed doing something more worthwhilethe key idea with any proper maggie stand is to make sure the speakers stand exactly vertical (not leaned forward or back) and raised to a height where the speaker is vertically centered onto the listener seating position
These both look like great inexpensive alternatives to the high priced spread. But one of the features of a different Maggie stand, the Mye Stand, is adding to the stability of the frame by attaching much higher on the frame. It looks like these TV stands have extensions that have been removed for Maggie use. Any thought to drilling another hole or two and using the extensions to help with the flimsy Maggie frame?
I posted the stands I bought for my LRS on FB groups, Link on Amazon https://www.amazon.com/dp/B0BLSM4KHB?psc=1&ref=ppx_yo2ov_dt_b_product_details I'm very happy with what I bought. They seem like they were made for the LRS. The only issue was I needed longer screws so 8 X 2" 10-24 machine screws at the ol' Ace Hardware.You will also need to use all the washers provided in the hardware kit to keep the screws the correct length.If you have carpet, I believe they are sturdy enough that you could drill and tap a 1/4-20 hole for some spikes.
