RM-30 Passive Radiator
0 Members and 1 Guest are viewing this topic. Read 1160 times.
tbrooke
« on: 3 Apr 2023, 02:13 pm »
I am getting ready to go down the RM30 upgrade to series II after a long pause. Since I do not have the plugs that Brian supplied it seems to me that just mounting a cover on the outside - in the bottom opening that is no longer needed and caulking it on the inside would work, Does this sound right -
Then to replace my active 10 inch Side woofer I found these at Parts Expresshttps://www.parts-express.com/search?keywords=10%20inch%20passive%20radiator&order=relevance:desc
Does anyone know which one?
It seems like I saw a link a while ago for a 10 inch passive but I couldn't find it
Jstower
Re: RM-30 Passive Radiator
« Reply #1 on: 3 Apr 2023, 04:03 pm »
tbrooke,  This is the one Creative Sound Solutions APR10 PASSIVE RADIATOR.  Good luck
Link;  https://www.css-audio.com/online-store
Link;  https://meniscusaudio.com/product/css-apr10/
John Casler
« Reply #2 on: 3 Apr 2023, 06:20 pm »
I liked and used the CSS 15" Passive for the VMPS Subs.
The design is great, in that you can add or subtract mass via washers.  You can also add putty, if you want the fine tuning ability.
GeorgeAb
« Reply #3 on: 17 Apr 2023, 05:00 am »
Greg's (user G E) guide is what I used for guidance. I found the detail and the pix he included gave me the confidence to understand what I was getting into and take the plunge.  https://www.audiocircle.com/index.php?topic=137131.msg1458796#msg1458796
Yes, just as you stated mounting MDF to cover the holes using caulk and some wood screws is what I did. G E included pics of his covers in his guide.
On the Creative Sound Solutions APR10 passive radiator. The radiator was $65 in 2018 and I see now is $90. As G E states the rubber gasket was slightly too large to fit in our cutout. I used scissors to remove some material to get it to fit. Greg used the 3M Strip Caulk which is great stuff.
Your two spare 10" Misco drivers will be gold to an RM40 owner looking for spares. Selling should pay for most of the upgrade. I sold mine and later I needed a set to spare a pair of RM40's that came into my life. I purchased a pair for what I thought at the time was an obscene price, but now looking back I consider them a bargain as they are made of unobtainiam.
