0 Members and 1 Guest are viewing this topic. Read 5978 times.
One thing that struck me is his comment that tube amps mimic natural harmonic distortion. If tubes more accurately reproduce sound as you would experience live, why is eliminating distortion and the measurement of such elimination so hotly contested and controversial? Is tube coloration a misnomer if it is in reality truer to “artistic intent”?Maybe this is why I actually like the sound of my NAD T758. It’s among ASR’s worst measuring amps.
really not trying to re-start the old subjective/objective debate here
Tube amps have a sound rich in Harmonics pleasant to the human brain, which makes them classic equip to listen music, for this reason they should not go out of fashion as long as the human being has this current brain configuration.
Any Amp that uses phase splitting has the Humpty Dumpty effect. Meaning cannot put the signal back together properly after splitting it. The reason I prefer SET amps. charles
Exactly. I like SET amps the best, then Push Pull tube amps second best, class A Solid state amps next, and everything else is not a viable long term option for me.Only thing, SET amps require a relatively high efficiency speaker with a decent impedance. If you have that, then they are magical.
+1. SET amps are the way to go, a long other important features as Hard Wiring, copper or silver, tube rectification, Alu Chassis, etc the matter is complex.
Fullrangeman,Will it make a difference if the SET amp is in one chassis or in mono blocks?
Difference in what area SQ ?1) I dont like mono tube amps.2) Also the ubiquitous stereo tube amps formula are a compromise, they use only one power Transformer for less cost.3) The correct way to go with tube amps are both channels in the same chassis with two Power Transformers, one for tube Heating, other for the hi voltage supply.
Different as to better imaging, blacker background more find details. But your suggestion is good. I will seek out designs with dual mono power supplies like a mirror image for left and right channels in one box. What about the OPT?
The OPT are mandatory tô be two for Stereo. Just being mono will no grant better sound, it will depend on the circuit and the construction.
Ok thanks! One more question. Would you rather have an ANk interstage 300b mono with their own transformers or 300b monos that use capacitor coupling with similar circuit but OPT on the second set of monos use better iron like Hashimoto.
