2-ch equivalent to 2014 9B SST2 5-ch?
0 Members and 1 Guest are viewing this topic. Read 1062 times.
James Romeyn
« on: 19 Mar 2023, 07:35 pm »
I heard and loved what I believe was the 9B SST-2 at 2014 RMAF (native multi-ch classical DSD program > five Magneplanars.)  What's the 2-ch equivalent 100W+?  I presume 2.5B-2.
Have some preferred the earlier -2/Squared amps over the current -3/Cubed series and if so, why?
Thanks in advance.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 2-ch equivalent to 2014 9B SST2 5-ch?
« Reply #1 on: 19 Mar 2023, 09:04 pm »
Hi James
The 9B was more like the 3B than the 2.5B
james
James Romeyn
« Reply #2 on: 20 Mar 2023, 04:56 am »
Thank you.
A big difference between the 2.5 and 3 series is that the latter is dual mono while the former is not, correct?
Respectively, do the 2.5B SST, 2.5B Cubed, 3B-SST and 3B Cubed have MOSFET or bipolar output transistors?
« Reply #3 on: 20 Mar 2023, 11:20 am »
Thank you.
Hi James
All the Bryston stereo amps have dual power supplies.
Bipolar in all our amplifiers.
james
James Romeyn
« Reply #4 on: 20 Mar 2023, 11:47 pm »
Thank you!
Was this the Bryston amp @ 2014 RMAF?  Native classic 5.0 DSD program > exaSound e28 DSD multi-ch DAC > Bryston 9B-SST2 5-ch > 5x Mageplanar 1.7
Within the smallest amp's power envelope: do the 2.5B SST2, 3B SST2 and 9B-SST2 all sound about the same?
« Reply #5 on: 20 Mar 2023, 11:56 pm »
Thank you!
Gees James I can not remember 2019 shows let alone 2014  :lol:
James Romeyn
« Reply #6 on: 21 Mar 2023, 12:08 am »
Yeah, that was a dumb Q!  In '14 or '15 the 9B was SST2?
That show display reminded me of the all-time best Kimber Isomike display w/Ray's proprietary 4.0 DSD recordings (Isomike requires huge venues, 6' tall heart-shaped baffle for 4.0 mic array) in a huge suite, four huge Pass Class A > dual 8' tall Sound Lab per each corner.  Kimber's room was better for about 20x higher cost.
