0 Members and 1 Guest are viewing this topic. Read 3113 times.
IT circle? This is as close as it gets, I think.
Fwiw, Synology NAS are very easy to setup and administer. I have 2 bay DS220. Much easier than my previous Netgear ReadyNAS.
Glad to see you made it past the first difficult steps. Once you have it configured it should do its job so well you'll forget you even have it.
Just to be sure: if you plan to move the NAS, shut it down from within the web app and let it turn itself off. Then you can move it and turn it back on once it's in place.
