TLP as headphone amp.
0 Members and 1 Guest are viewing this topic. Read 1641 times.
simgrant
« on: 21 Apr 2005, 11:17 pm »
Hello fellow Aksaphiles,
    This might be a silly question, but could I use my TLP to drive a a pair of headphones, using a cd as the source. I am not sure what the output impedance of the TLP is but it must be pretty low.
Regards, Simon.
SamL
« Reply #1 on: 22 Apr 2005, 01:45 am »
No sure if TLP will be able to drive a headphone but an alternative is to drive the headphone with your aksa power amp as per Elliott's site http://sound.westhost.com/project100.htm
It will add quite a bit of complexity into the case work & wiring.
Have fun,
Sam
simgrant
« Reply #2 on: 22 Apr 2005, 02:08 am »
Thanks SamL,
    I had overlooked some previous threads before posting which I have since found. I had wanted the TLP to act as a standalone headphone amp but it seems a buffer is required. I will have to look further into the threads for recommendations.
Regards, Simon.
AKSA
« Reply #3 on: 22 Apr 2005, 07:11 am »
Hi Simon,
Thanks for dropping in!
You are right, however, and you will need a buffer.  The Zout is 130R, which should be OK for headphones over 2K, but no good for ordinary 32R or lower.
There are simple opamps which would do the job;  you could use an 1875 for this job, but it's basically a power amplifier.  It will sound OK, but not quite as good as an AKSA!
Hugh
simgrant
« Reply #4 on: 23 Apr 2005, 07:14 am »
Thanks, Hugh,
    an LM1875 would have huge amounts of power. I remember reading a project by someone called Sheldon Stokes where a headphone amp used a HQ opamp input and class A mosfet output. But then a good old bipolar stage should be fine as the TLP won't mind a transistors low input impedance.
Regards, Simon.
