So I picked up a pair of M3 Turbo S and then did this
0 Members and 1 Guest are viewing this topic. Read 3083 times.
skifasterslc
I found this pair on usaudiomart a couple of months ago and wanted to change the color from the standard black to something more my style. I considered painting, but I am no good at it. I decided to have them "wrapped" by a local installer that primarily installs vinyl wraps on cars and trucks.  One of the many benefits of using a wrap over painting, is that is easy to go back to stock color by removing the wrap. FYI the color is MATTE TRENTON BLUE K75544, The material and install came to $160.  The only problem was finding the shop, the job was to small for some. Oh and I am VERY HAPPY with these speakers, will not be changing anytime soon, I appreciate all the wisdom in this forum!  Here they are
System at the moment, Bluesound node2i > Qobuz > Coax digital out> SMSL M500 MkII dac/pre > Buckeye Hypex NC252MP amp >  Spatial M3 Turbo S + SVS SB-2000pro
Samac
Re: So I picked up a pair of M3 Turbo S and then did this
« Reply #1 on: 9 Mar 2023, 11:44 pm »
They look great, skifasterslc. Love that color. :thumb:
Scott
DaveWin88
« Reply #2 on: 10 Mar 2023, 12:36 am »
Fantastic looking. Great option, thank you for sharing this.
JCarney
« Reply #3 on: 10 Mar 2023, 01:16 am »
It looks like it was very well done. I really like new look, fits the room colors better, and it just looks bloody cool. $160 well spent.
JCarney
kd4ylq
  • Esse Quam Videri
« Reply #4 on: 10 Mar 2023, 03:22 pm »
Looks like you got some great results! Did you have to remove the drivers and xover plate to have the wrap done?
skifasterslc
« Reply #5 on: 10 Mar 2023, 03:40 pm »
kd4ylq,
No the drivers and other parts stayed in place, i did not have them wrap the rear baffle, just the front and 3 sides
Mr. Big
« Reply #6 on: 10 Mar 2023, 06:01 pm »
Now that was thinking outside the box, they look good, they did a good job.
DBT AUDIO
« Reply #7 on: 10 Mar 2023, 11:54 pm »
Really nice color choice!!!
sockpit
« Reply #8 on: 11 Mar 2023, 09:20 pm »
How did it affect SQ?  🤣
RonP
« Reply #9 on: 25 Mar 2023, 03:59 pm »
Hopefully it doesn't color the signal any.  :D
hk29
« Reply #10 on: 26 Mar 2023, 02:55 am »
Nice!  I was thinking about the same thing so thank you for giving it a shot and reporting back.  There was also youtuber did the same but DIY: https://youtu.be/mM0uWHXi8wA
They look great!
skifasterslc
« Reply #11 on: 28 Mar 2023, 02:49 pm »
Well I have to admit, "Kind of Blue" sounds better than ever
Thx for youtube link HK29
