SOLD Digital Amp Co. Cherry Maraschino SOLD
0 Members and 1 Guest are viewing this topic. Read 709 times.
joessportster
  • Set & Single Driver Bliss
« on: 6 Mar 2023, 10:32 pm »
As most of you here will know these are the creations of the late Tommy Obrien. This pair is 100% Functional they have the marble bases with raw aluminum amp enclosures. Includes the 48 Volt power supplies. This will get you 250 WPC into 8 Ohms and 400 WPC into 4 Ohms. You can up the wattage if you get higher voltage power supplies (Not sure why anyone would need to) The amps sound superb with no digital artifacts / fatigue. Best Digital I have heard (Perhaps thats why this is my 3rd set)  As seen in the pics the Balanced / single end adapters are included. I also have the original packing / boxes which will be double boxed
Trades I will consider, Tube amp 30 wpc+ in output, Tube DAC's
Something of NOTE for those unfamiliar with these (and all digital amps) if you short the speaker binding posts you will fry the Jfets. IT IS A GOOD RULE OF THUMB TO FOLLOW THAT YOU CONNECT ALL CABLES BEFORE YOU ADD POWER TO THE AMPS
Asking 1500.00 OBRO (or best REASONABLE offer) Buyer is responsible for shipping and any fees, Location is 28352 North Carolina
Only selling because my Pre-amp now allows me to use my Tom Tutay Heathkit amps.
« Last Edit: 16 Mar 2023, 11:55 am by joessportster »
GregC
Your suggestion is a good one.  Another suggestion is to use tight fitting banana plugs to reduce the chance of a spade coming loose and touching across the binding posts.  Tommy's amps do sound superb.
