Open Baffle Subs
0 Members and 1 Guest are viewing this topic. Read 1749 times.
BrandonB
Open Baffle Subs
« on: 28 Feb 2023, 09:59 pm »
What is the benefit from going from a dual open baffle sub to a triple open baffle sub?
Early B.
Re: Open Baffle Subs
« Reply #1 on: 28 Feb 2023, 10:06 pm »
More of everything -- bass, soundstage, dynamics, improved imaging, better midrange, etc.
mlundy57
« Reply #2 on: 28 Feb 2023, 10:54 pm »
Cleaner, more effortless. With duals, each driver does half the work. With triples, each driver only has to do 1/3 of the work. So none of the drivers have to work as hard.
« Reply #3 on: 1 Mar 2023, 12:05 am »
I have duals in my upstairs setup and triples in my downstairs setup.  The obvious/expected benefit is more headroom, and that's certainly true.  But the thing I didn't expect is just how much more percussive and just downright MEAN the triples sound.
HAL
« Reply #4 on: 1 Mar 2023, 12:14 am »
If you are going to LSAF 2023 in June in Dallas TX, you can hear the 3x12's with planars if interested.  Will have them in my room.
Time for some pipe organ music! :)
Will have Qobuz for other music.
corndog71
  • Some people call me Rob.
« Reply #5 on: 1 Mar 2023, 12:20 am »
This info is not helpful!  :lol:
BrandonB
« Reply #6 on: 1 Mar 2023, 12:46 am »
So the subs actually play some of the midrange or are they taking base away from the mid woofers?
mlundy57
« Reply #7 on: 1 Mar 2023, 01:54 am »
They cover mid and upper bass, up to 200Hz if need be, but it depends on what you are pairing them with.  With Wedgies you would need to go up to 200Hz, with my NX-Otica MTMs I cross at 80Hz and with full size NX-Oticas it would be 60Hz or lower.
dayneger
« Reply #8 on: 2 Mar 2023, 06:01 pm »
With the NX-Otica MTMS paired with the dual servo subs, if you had a high pass filter that you could freely set to drop them higher than their full range, at what frequency does the quality of the MTM bass sound better than the servo subs?
Does that frequency change with how loudly you're listening?  For example, below 85 db cross at 80 Hz, at 90-95 db cross at 110 Hz, 100 db and over 150 Hz (random examples).
mlundy57
« Reply #9 on: 2 Mar 2023, 06:19 pm »
The point you want to cross to the subs is where the main speakers are 6dB down. This will vary depending on the room and the setup. In my room it turns out to be 80Hz. Some people can determine this point by ear. I'm not one of them so I use REW.
I only use a high pass filter on the MTMs to roll off the bottom octave but you can high pass the MTMs higher if you want to. What SQ differences there would be by filtering and crossing higher I don't know because I haven't tried that. As a point of reference, in the full size NX-Oticas, the MTMs are crossed to the 4 bottom M165s at 200Hz.
dayneger
« Reply #10 on: 2 Mar 2023, 09:33 pm »
Thanks, Mike!  Very useful to have that as a reference point.
Makes me curious how much the quality of the amp plays into this spectrum as well.
mlundy57
« Reply #11 on: 2 Mar 2023, 09:48 pm »
Quite a bit. The NX-Oticas, either MTM or full size, are very revealing so the better the signal they get is, the better the sound they produce. This doesn't mean you need an expensive amp, or any other component, to get great sound from them.  Just that the better the electronics are, the more you get from the speakers.
