The TEAC 700P turn-on delay.
0 Members and 1 Guest are viewing this topic. Read 1100 times.
franjy
« on: 21 Apr 2005, 12:03 pm »
Thinking of getting a TEAC modded and concerned about
this part's dependability. If it should fail is this part (relay?) easy to get and fix?
JoshK
« Reply #1 on: 21 Apr 2005, 01:33 pm »
Hi Franjy,
I can only presume you are referring to some kind of soft start mechanism.  If you were to get your equipment modding, typically the modders warranty their work and should be able to answer your question more specifically.  However, typically relays are quite easy to obtain, if not the exact relay then one with a similar rating.
HTH,
Josh
