0 Members and 1 Guest are viewing this topic. Read 8124 times.
Looking to buy a tube integrated amp that is built in the USA. Would love a Decware but not willing to put up with that wait. Who should I consider. I know of the following:McIntoshCaryRogue AudioDecwareAudio ResearchRaven AudioAre there others I should be considering?
Forget this famous brands, they are expensive for what they offer and are freezed products, with minimal or none options to you choose, instead try order a Custom amp with Dennis Had, Cary Audio founder.His amps run a plethora of power tubes with the big tone 6SN7 tube and have just a few things to modify be OK, to namely:1) A larger chassis to facilitate maintenance and decrease self noise.2) Hard wiring(no stranded wire) with conventional lead solder, no Euro Rohs compliant solder.3) Bigger transformers, mainly power and OPTs.
Is here a webpage? Do I just google Dennis Had?
Dennis dont have a site, he sells at Ebay as Radioman731, contact him via Ebay:https://www.ebay.ca/sch/i.html?_nkw=&_armrs=1&_ipg=&_from=&_ssn=radioman731
Made in America:Aric Audio https://aricaudio.com/Radu Tarta https://simplepleasuretubeamps.com/about/
