POSTPONED Rega Mira Integrated - Bad Volume Control
0 Members and 2 Guests are viewing this topic. Read 2484 times.
rockadanny
« on: 20 Feb 2023, 01:32 am »
POSTPONED ... Going to see if I can still use just the power amp section. If not, I'll release this back to the wild. (you all).
30064 Rega Mira Integrated. Worked perfectly until volume control failed. Now operates only at full volume.
« Last Edit: 21 Feb 2023, 03:43 am by rockadanny »
vrao81
Re: FREE Rega Mira Integrated - Bad Volume Control
« Reply #1 on: 20 Feb 2023, 01:49 am »
I wonder if you could purchase a cheap external passive pre-amp and use that to control volume.
rockadanny
« Reply #2 on: 20 Feb 2023, 02:40 am »
It does have a power amp input for a line level input, which I think is for?
Yes? Maybe?
Letitroll98
  • Too loud is just right
« Reply #3 on: 20 Feb 2023, 10:38 am »
Where are you located, I'd drive over today.
« Reply #4 on: 20 Feb 2023, 10:52 am »
Rega small amps have a sweet sound  :thumb:
rockadanny
« Reply #5 on: 21 Feb 2023, 03:40 am »
Agree. So sad this happened!
Letitroll98
Re: POSTPONED Rega Mira Integrated - Bad Volume Control
« Reply #6 on: 21 Feb 2023, 11:36 am »
Yes, it will most likely work perfectly unless there are problems beyond what you've encountered.  Any of the line level inputs should work, a preamp puts out the same 2v maximum that a CDP or DAC does, but with a volume control included.  My two DACs both have volume controls and I can hook them directly into my power amps, which is basically what you have.
howburger
« Reply #7 on: 23 Feb 2023, 05:11 am »
I have other Schiit gear but haven’t used this one. It fits the bill, and at $50, if it’s not transparent and quiet enough, you can use it on something else.
https://www.schiit.com/products/sys
Harold
