Impressions Finishing Touch / Hangers
AllanS
« on: 15 Feb 2023, 06:07 am »
Adding hinged screw caps finished off Impression diffuser panel in black
These Canvas Hangers made mounting the 2x2 panels ridiculously easy and leave them tight against the wall. Simply line up panel on the wall and push in.  They are especially helpful if you’re mounting several in direct contact with each other.  No measuring and fussing with typical hangers.
The fabric made attaching the hangers to the panels a bit of a challenge.  The plastic is tough enough to hammer additional brads through.  Were I to do it again I’d probably slit the fabric where the hanger mounts.
JWL.GIK
    • GIK Acoustics
Re: Impressions Finishing Touch / Hangers
« Reply #1 on: 15 Feb 2023, 02:45 pm »
Nice work!!!!
