Beryllium replacement diaphragm?
0 Members and 1 Guest are viewing this topic. Read 1819 times.
kd4ylq
  • Esse Quam Videri
« on: 13 Feb 2023, 02:39 pm »
Does anybody know the brand & model number of the upper woofer with the integrated horn driver on the Spatial M3 Turbos? I don't see branding labels or ID on any of the drivers and am curious if there might be a beryllium replacement diaphragm for the horn driver.
Spatial Audio
Re: Beryllium replacement diaphragm?
« Reply #1 on: 13 Feb 2023, 03:28 pm »
The coaxial unit in the M3 is a custom 15 inch version made for Spatial by Eminence. The horn compression driver is a separate device that screws into the back of the coax. Im not aware of any replacement diaphragms made of Beryllium.
Clayton
