Dac modules
0 Members and 1 Guest are viewing this topic. Read 1060 times.
mr_bill
Dac modules
« on: 8 Feb 2023, 06:17 pm »
Hi James,
Is the same dac module used in the BP17 cubed preamp and the B135 cubed integrated?
Has anyone figured out a way to use USB with either of these units/dac board since they only have toslink and coax digital inputs?  An outboard converter maybe?
Bill
BCRich1
Re: Dac modules
« Reply #1 on: 8 Feb 2023, 11:31 pm »
Hi Bill,
You would need a USB to SPDif Convertor.
Lots to choose from.
Mike
GrooveControl
Re: Dac modules
« Reply #2 on: 9 Feb 2023, 04:36 am »
The Topping D10s is one that doesn’t require a separate power supply.  I have used it as a full blown DAC and liked it. You can use it as just a converter if you have a better sounding Dac.
zeeman
Re: Dac modules
« Reply #3 on: 17 Feb 2023, 06:51 pm »
Hi James,
Bill
Plug a Bluesound Node via coax output into the B-135 DAC.  Sounds beautiful.
