Baffle Step Comp.
0 Members and 1 Guest are viewing this topic. Read 810 times.
whydontumarryit
Baffle Step Comp.
« on: 4 Feb 2023, 09:08 pm »
Did the 160hz xover freq. have anything to do with eliminating the need for baffle step compensation. If so, was there a noticeable improvement in the power response vs going to a higher xover freq.
Also, during development why was a closed box first considered then out of the blue it went ported.
Re: Baffle Step Comp.
« Reply #1 on: 4 Feb 2023, 09:35 pm »
What is the woofer?
Sealed boxes have to be much bigger than BR.
whydontumarryit
« Reply #2 on: 5 Feb 2023, 12:59 am »
I was talking about Bryston's loudspeakers.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 5 Feb 2023, 11:42 am »
The speaker's measured performance generally indicates a well-balanced design.
And again I must point out that excellent cumulative spectral-decay plot.
It is uncommon to see a large, affordable tower speaker with so clean an initial decay.
John Atkinson
