Sold! Yamaha YP-D6 Direct Drive Turntable
0 Members and 1 Guest are viewing this topic. Read 1161 times.
jdoyle
« on: 4 Feb 2023, 07:01 pm »
Asking Price: $425.00 (plus shipping cost). Price lowered to $375.00 Item has been sold!
The unit is heavy, about 24 lbs!
Will be packed with great care in a heavy duty carton.
This was my brother’s, and it was always well cared for, but the dust cover has some light scratches, I’d rate it a 6 or 7 out of 10
Purchased in ‘78. Last used probably in the late eighties.
Stanton cartridge L727E is on it now.
Also included is the ADC PSX-40 it replaced.
Copy pasted from Vinaudio:
The Yamaha YP-D6 is a beautiful device!
Built in 1977, it has a very clean look which gives it a fragile appearance, but it is a heavy device, the build quality is very good, typical of Yamaha.
S-shaped arm, Auto-Return at the end of the record.
Performance specs are good: signal to noise ratio 70dB, while wow/flutter is around 0.035%.
It runs well, stable, the controls are simple, located on the right with the strobe light on the opposite side.
It is a very good performing device, nice clean sound!
They are hard to find and their value is going up…
Specifications
Drive system: direct drive
Motor: 12-pole, 24-slot dc servo motor
Platter: 300mm die-cast aluminium, 1.6kg
Speeds: 33 and 45rpm
Speed variation: +-3%
Signal to noise ratio: better than 70dB
Wow and flutter: less than 0.035% wrms
Tonearm: S-type static balance
Effective length: 222mm
Overhang: 17mm
Suitable cartridge weight: 4 to 15g
Headshell: aluminium die-cast plug-in type
Dimensions: 470 x 156 x 359mm
Weight: 10.6kg
« Last Edit: 23 Feb 2023, 07:22 pm by JDoyle »
orthobiz
Re: FS: Yamaha YP-D6 Direct Drive Turntable
« Reply #1 on: 4 Feb 2023, 11:09 pm »
Nice looking deck. Wasn't sure from the description:
Does it run? Does sound come out of it?
Paul
jdoyle
« Reply #2 on: 4 Feb 2023, 11:53 pm »
Hi Paul, yes it runs, the top pic is the strobe just today.
As far as sound goes, it was working fine when last played.
I have no reason to believe that it won’t play great now.
 I’ll offer a full refund if not satisfied
jdoyle
« Reply #3 on: 16 Feb 2023, 01:00 pm »
Bump. Price lowered to $375.00
Rocket
« Reply #4 on: 18 Feb 2023, 02:30 pm »
Hi,
Don't overlook look these vintage turntables as they would be much better than the current offerings from Rega, project etc. Find a good turntable technician and have it serviced and install a good cartridge and your all set to go.
Good luck with the sale.
Cheers Rod
bkatbamna
« Reply #5 on: 21 Feb 2023, 09:12 pm »
I'd take this DD Yamaha over almost any belt drive turntable.
GentleBender
« Reply #6 on: 22 Feb 2023, 12:30 pm »
Where would this ship from?
jdoyle
« Reply #7 on: 22 Feb 2023, 03:07 pm »
Ships from 14127.
 I will pack it perfectly and would ship UPS ground, you would pay whatever that cost is.
