Industry Circles
GR Research
Danny Richie
MTM with M130-16's, T26SG and Passive Radiator
0 Members and 1 Guest are viewing this topic. Read 1235 times.
AndrewDIY
3 Feb 2023, 01:11 am »
I am considering a M130-16/T26SG based MTM. My design goal is 1) have a relatively high-sensitivity (above 90db) speaker and 2) with a box as shallow as possible w/o sacrificing too much bass. Would a passive radiator (perhaps the
https://www.madisoundspeakerstore.com/passive-radiators/sb-acoustics-sb15sfcr-00-5x8-passive-radiator/
) work well with these drivers? And how do I calculate the box size considering the passive radiator?
Hobbsmeerkat
Industry Participant
Re: MTM with M130-16's, T26SG and Passive Radiator
3 Feb 2023, 01:51 am »
We actually just finished the crossover design work for the M130/16 versions of the X-MTM & X-CS
The towers will be a transmission-line design just like the A/V-3 they're replacing.
A passive radiator version should work also.
The box volume will need to be about the same as a ported/vented box, but cabinet design is a little beyond my understanding at the moment.
AndrewDIY
Reply #2 on:
3 Feb 2023, 01:21 pm »
Awesome to hear you all are working on this. I love the idea of a transmission line speaker. I presume that would play deeper than an MTM bookshelf with passive radiator. What have you found to be the optimal airspace for those drivers in the MTM configuration?
Wigand
Reply #3 on:
6 Feb 2023, 11:51 pm »
Uh interesting; do you already have cabinetplans for it?
The MTM 130 I meant.
Hobbsmeerkat
Reply #4 on:
7 Feb 2023, 01:39 am »
Not sure, I know we have the plans for the old AV-3 & AV-3S that they are replacing, but I think the plans still need to be adjusted for the Encore/T-26 tweeter.
We'll have it ready soon as were ready to launch that kit.
Industry Circles
GR Research
Danny Richie
