Bryston 7B’s with REL sub
0 Members and 1 Guest are viewing this topic. Read 725 times.
dt1296
« on: 30 Jan 2023, 11:23 pm »
Newish to board and still unable to search so hoping someone would be willing to share link or information on wiring a REL sub with high pass connection to a single 7B or if I’m able to connect to the positive and negative on one 7B and use a runner wire to the positive of the other amp. Just not sure if this wiring will damage either the sub or the amps. Also not sure if the 7B’s (SST) are differential amps. Any info passed along is greatly appreciated.
Don
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 7B’s with REL sub
« Reply #1 on: 31 Jan 2023, 12:43 pm »
Hi Don - check with Mike on that - I think there may be an issue with the grounds.
james
[email protected]
