Step Up (Or Two) From BMR Monitor
0 Members and 1 Guest are viewing this topic. Read 1814 times.
catastrofe
  • "That's what credit cards are for. . ."
« on: 28 Jan 2023, 03:46 pm »
Wondering which monitor(s) are a significant step up in performance from the BMRs?
Powering with a Lyngdorf TDAI-1120 (60W @8 ohms, 120W @ 4 ohms).
AllanS
Re: Step Up (Or Two) From BMR Monitor
« Reply #1 on: 29 Jan 2023, 01:23 pm »
I’m not sure that it matters, but what generation of BMR do you have in mind?
I’m also interested to hear any opinions.
DMurphy
    • SalkSound
« Reply #2 on: 30 Jan 2023, 08:35 pm »
Hmmmm.   No one seems to be offering an opinion.  So--I think improvements over the BMR will be more in the area of power handling than accuracy or bass extension per se.  For example, the new BePure1 will play a good bit louder before the woofer runs out of travel.
catastrofe
« Reply #3 on: 31 Jan 2023, 01:32 pm »
Thanks Dennis. I should add that I'm running dual subs, so lower end extension isn't the most critical factor. Efficiency (I have 60W/channel at 8 ohms and 120W at 4 ohms) and dynamic capability would probably be my two top "technical" priorities. Accuracy, imaging, and soundstage are also critical.
