0 Members and 1 Guest are viewing this topic. Read 8428 times.
aaannnnddd just like that, the what center should i use with my bepure2's is solved. will be ordering one soon.
Jim, do you have any of the 4.5" drivers to play with?If so, will you be designing a 3-way with them?
The 6.5" Purfi's don't require a large cabinet. The problem for 2-way monitors is that the appropriate port for the optimal box is too long to fit. Hence the passive radiators.
