First tube amp - Eico 2050
0 Members and 1 Guest are viewing this topic. Read 1696 times.
jeffh
« on: 21 Jan 2023, 04:35 am »
I picked up this Eico 2050 integrated amp a few weeks ago at an estate sale. I’ve only listened a little, but is sounds pretty good.
opnly bafld
Re: First tube amp - Eico 2050
« Reply #1 on: 21 Jan 2023, 01:19 pm »
Nice.
Has it been checked recently for bad and out of spec caps and resistors, etc?
jeffh
« Reply #2 on: 21 Jan 2023, 02:47 pm »
Nice.
Yes, before I  even turned it on, I had a tube tech go through it and check everything. He found a couple of bad resistors and caps and a cold solder joint. Everything else tested good. Even the original tubes.
« Last Edit: 21 Jan 2023, 05:45 pm by jeffh »
S Clark
« Reply #3 on: 21 Jan 2023, 03:09 pm »
Those old Eico amps were surprisingly good.  Gary Dodd modified a couple of them for me and thought they had rather nice sounding transformers.  When I taught high school physics, I used to pick them up for after school projects. At that time they were cheap.   I've still got a couple out in the shed.
You probably noticed that most of the tubes are old Mullards- warm and musical.
lokie
« Reply #4 on: 21 Jan 2023, 04:13 pm »
Love me some Eico's. I have a pair of HF-60's as my everyday drivers.
Hard to find on the cheap anymore.
Are 6L6's a drop in driver tube  replacement?
jeffh
« Reply #5 on: 22 Jan 2023, 08:35 pm »
That I do not know.  I would defer to the experts around here to answer. Currently it has the four original Eico 7591’s stamped “made by Westinghouse”
opnly bafld
« Reply #6 on: 22 Jan 2023, 09:27 pm »
Output tube?
No, 7591 and 6L6 have different connections (pinout).
dB Cooper
« Reply #7 on: 22 Jan 2023, 10:14 pm »
I built several Dynaco pieces. Eico was probably their most direct competitor. Interesting design.
