iFi Zen stream tip
0 Members and 1 Guest are viewing this topic. Read 7092 times.
Kw6
iFi Zen stream tip
« on: 8 Jan 2023, 06:48 pm »
At minimum try to hard wire into stream using CAT6 ethernet cable!
whell
Re: iFi Zen stream tip
« Reply #1 on: 21 Jan 2023, 03:34 pm »
Why, and what differences did you encounter when swapping out CAT 5 for CAT 6?  Unless you have a 1GB internet signal from your internet provider, CAT 5 is well within spec for a home internet signal.
Kw6
« Reply #2 on: 29 Apr 2023, 06:59 pm »
I haven't really compared I use hardwired cat7 to Zen stream from my Asus router. No more drop outs. Sound is very sublime. I can't imagine any better. I think you will need $7k streamer to beat this.
